RCU Forums - View Single Post - CMP Hellcat
Thread: CMP Hellcat
Old 02-27-2005 | 06:03 PM
  #82
mikejdad
My Feedback: (39)
Default RE: CMP Hellcat
Richard, your landings looked pretty good to me. No bounce and very normal that I could see on your video, of course those were with power on. I'm fitting my CJ retracts and it appears a mounting block needs to be added as the built in plate would recess the retract to deep into the wing. Also it appears the mounting flanges on the retracts need to be ground dowm as they are too wide to fit the wing opening. Am I seeing things correctly? I think I'll make a plate to go aroung the opening cut (epoxy a plate of plywood on both sides)in the spar. Thanks mike J.
