RCU Forums - View Single Post - Fuel for Dummies!??
Old 02-27-2005 | 09:12 PM
carrellh's Avatar
carrellh
Default RE: Fuel for Dummies!??
ORIGINAL: techfueldog
Thanks for this thread - I've run into the exact same situation and have been researching the 3 line vs 2 line filling design for a week or so - glad you folks put up the schematics as they are very helpful. I built my tank as a 3 line system thinking I'd have trouble disconnecting the line from the carb inside the cowl, but then got the GP Easy Fueler Valve which makes it a clean installation for a 2 line system. Any suggestions on what I should use to seal my open 3rd line? Is epoxy a possibility or does the fuel act like alcohol and loosen it up?
Eventually epoxy would be damaged by the alcohol but it might take a really long time before it matters. I wouldn't risk it.
You could use about an inch of line with one of these plugs
http://www2.towerhobbies.com/cgi-bin...?&I=LXK138&P=0
Brass tubing can be squeezed flat with pliers and sealed with solder.
