RCU Forums - View Single Post - WHAT Motor To put ??????????????????
Old 02-27-2005 | 09:13 PM
push rodz's Avatar
push rodz
Default RE: WHAT Motor To put ??????????????????
The Pizza Boxes are a lot of fun...........what kind of AUW (all up weight) are you looking at?
If you're in the 9 - 15ish ounce weight range then the Himax 2015-4100 should do the trick. If your'e over that up to about 22 ounces then the Himax 2025-4200 will work.
There are other power plants out there that would work as well but these are the two that I use and am familiar with.
Good luck!
