RCU Forums - View Single Post - inverted flat spin
Old 09-18-2002 | 02:10 PM
f2racer
Default Upright flat spin?
Originally posted by Cheech
At this point you are full down elevator, full left aileron, full right rudder and NO throttle . This will start the inverted spin. Let it go for a couple of revolutions then make it flat.
To make it a FLAT spin, start adding throttle AND creeping the ailerons over to the other side . How much throttle and opposite aileron is up to you and the plane. Leave the rudder all the way right and the elevator shoved forward. If it is capable of a flat spin, it will flatten out nicely with opposite aileron and the addition of some throttle.
Does this mean to make a plane do an upright flat spin, the only difference is to give the plane full up elevator?
