Does this mean to make a plane do an upright flat spin, the only difference is to give the plane full up elevator?
Just remember, when you're doing an inverted flat spin, you give RIGHT rudder, and flatten it out with RIGHT aileron. When doing a regular flat spin, you give LEFT rudder, and flatten it out with RIGHT aileron again.
I have and have had planes, where I've had to feather all but the rudder input to obtain a flat spin. If I gave full elevator, it would tumble out, if I gave full full aileron, it would roll out. Having the plane good and tail heavy and lots of throw on rudder is a good start. Also, feathering the throttle will some times make the flat spin better, spinning more around its CG.
DKjens
