Congratulations on some good first flights. Sounds like you got it working/flying good. On the Saito engines, they are set very rich on the low end jet. That is where you must lean it down the most. You can lean it quite a bit there and not have any problems. You sould be able to get at least 14 minutes out of a tank of gas. Mine does that easily.
Barry
