RE: Kangaroo Engine Mount Problem
I did two things to address this. First, I used flat head wood screws to hold the engine mount on and I slightly countersunk them into the aluminum bracket, and second, I put a couple of pieces of foam mounting tape over the screw heads. This greatly reduced the marking of the case, although you can still see where it was clamped in. The external case on the Jetcats is cosmetic, by the way.
Bob
