RCU Forums - View Single Post - techniques for cutting the canopy...
Old 02-28-2005 | 02:35 PM
dbarrym's Avatar
dbarrym
My Feedback: (47)
Default RE: techniques for cutting the canopy...
I've never seen a Starfire canopy, but unless it's very thick or stiff, R/C car (lexan) shears - the ones with the curved tips - work great.
If it's brittle , very heavy or thick you can use a Dremel cutoff wheel. I usually outline the canopy cut line area in masking tape and then use a thin point magic marker to draw on the cut line, usually + 1/32'1/16" or so then sand to the final line using a sanding block and 150 to 220 grit.
Barry
