techniques for cutting the canopy...
My Feedback: (32)
NE
Hi Everyone,
I'm getting closer to finishing my Starfire and nearing the part of cutting the canopy and making it fit. I have done other canopies in the past, but wondered if there is a easier way to cut it and get it to fit?
Thanks, Michael
Thanks, Michael
My Feedback: (47)
I've never seen a Starfire canopy, but unless it's very thick or stiff, R/C car (lexan) shears - the ones with the curved tips - work great.
If it's brittle , very heavy or thick you can use a Dremel cutoff wheel. I usually outline the canopy cut line area in masking tape and then use a thin point magic marker to draw on the cut line, usually + 1/32'1/16" or so then sand to the final line using a sanding block and 150 to 220 grit.
Barry
Barry
