RE: Anyone using Hitec 5625MG's?
They'll be fine for a 28% plane on 6v.
Here's a hint if you want to trade speed for torque. You can replace the gears with a set for a 5645 and it becomes a 5645. The only difference between the two servos is the gear ratio, change the gears and you change the specs.
TF
