RCU Forums - View Single Post - Centre of gravity calculation
Old 03-01-2005 | 07:10 AM
rcguy!'s Avatar
rcguy!
My Feedback: (69)
Default RE: Centre of gravity calculation
ORIGINAL: john agnew
Could someone be good enough to check the CG calculation as per the sketch below.
Tapered wing with straight trailing edge.
Root chord 450mm
Tip chord 250mm
Mean chord = 350mm
25% Cg = 25% of 350 =87.5 mm plus distance from mean chord to leading edge = 100 =187.5mm behind leading edge?
Thanks you mathematicians!
John Agnew
Here ya go...
http://www.geistware.com/rcmodeling/cg_calc.htm
Dave Rigotti
