RCU Forums - View Single Post - Condor Pro Clutch problem
Old 03-01-2005 | 10:19 AM
MassiveMods's Avatar
MassiveMods
Default RE: Condor Pro Clutch problem
the clutch shoes ? do you mean aluminium shoes as opposed to nylon ones ? If so its a preferance.. Aluminium will egage later and give a little more slip for low traction surfaces.. whereas nylon will give more grip and have better wear.. Also make sure your clutch shoes are trailing not leading ..
