RCU Forums - View Single Post - Eclipse 7 question
Old 03-02-2005 | 11:55 AM
Brendan Lugo's Avatar
Brendan Lugo
Default RE: Eclipse 7 question
ORIGINAL: cruzomatic
Hi, I have an Eclipse 7 and need some help. I'm wiring a P51 with flaps and retracts. Do I have the channel line up correct?
1. right aileron
2. rudder
3. engine
4. elevator
5. retracts
6. left aileron
7. flaps
My second question is can I control the flaps with either the channel 7 switch or the flight mode switch vs. the VR 2 knob? What I'm wanting to do is have it set on the 3 position switch to have them set at full up, 15% down and full down? Is this possible with the Eclipse? If not then what about with the Optic 6?
You have your channel 2 and your channel 4 reversed. If you use a p-mix (1 or 2) you can have the flap control from the VR2 knob activated with the channel 7 switch. The Optic uses a slider for flaps instead of a knob like on the Eclipse. The slider is located on the side of the transmitter.
