RCU Forums - View Single Post - Can I use flexible pushrod for the elevator?
Old 03-02-2005 | 07:29 PM
ecmiller
Default RE: Can I use flexible pushrod for the elevator?
I like flexible push rods...alot. I only glue the outer tube at one end so it can expand and contract inside the plane without binding. If you glue it at both ends the outer tube will develop curves because it will not move through the structure.
You'll always have to dial in trims a little here and there.
