RCU Forums - View Single Post - Closed Loop Elevator
Old 03-03-2005 | 07:15 AM
CougarRules's Avatar
CougarRules
Default Closed Loop Elevator
Hi i have a model with a closed loop elevator ( two wires for each elev half) and after tightning up all the wires i can still move the elevator up and down with the servo still, but i dont want to over tighten. Is there any guage as to how tight the loop should be? Thought id get a better response in this forum as unsure where else to post thanks cougar. I am thinking it would maybe easier to use mini servos in the tail if i cant get a satisfactory result with the wires? The model is a weston Hype 3D if any of you know it.
Cheers again cougar.
