RCU Forums - View Single Post - How to make a prop hub with magnet
Old 03-03-2005 | 12:55 PM
smallplanes
Default RE: How to make a prop hub with magnet
Ignition will not fire until it just passes the magnet. I drill and press it in with a drill press and put some epoxy in the hole. If you drill it to big then you will need to punch it with the point of a tap or something sharpe. Punch it in four places around the magnet (12 oclock 3-6 and 9 oclock)
I might have a pic i will have to check and see.
smallplanes
