RCU Forums - View Single Post - How to make a prop hub with magnet
Old 03-03-2005 | 11:08 PM
mikenlapaz
Default RE: How to make a prop hub with magnet
What will be the size of the magnet ( and the hole to be drilled on the hub) . I understand that the hole should be a round one. Is only one hole ( and the magnet) enough?
Zafer, could you tell us some more about the 'TYPE' of electronic ignition you plan to use. You fellas with more experience correct me if need be, I think there are some electronic ignitions available or that can be homemade that require more than just a single magnet passing a sensor. If may be possible that Zafer is planning on using one different than say the CH type that I use.
