RCU Forums - View Single Post - Mix Aileron into each Elevator?
Old 03-03-2005 | 11:26 PM
GordonFreeman's Avatar
GordonFreeman
Default Mix Aileron into each Elevator?
Now that I have a plane with separate Elevator halves, I was wondering the effect of mixing the Aileron into each elevator half. Each half would act like a little Aileron when you you Aileron. Obviously this should increase roll rate, but what other effect would it have? What about mixing it the opposite way, right Aileron up, right Elevator down?
This would be akin to Flaperon and Spoileron, but the other way. The Aileron would move the coresponding Elevator half.
Is there an easy way to mix this in on my 7CAP? The only way I could seem to mix it was by using two programmable mixes.
