RCU Forums - View Single Post - Battery wiring opptions
Old 03-04-2005 | 08:55 AM
kregan's Avatar
kregan
Default RE: Battery wiring opptions
After talking with Kurt, and reading hundreds of posts on battery
setup's I decided to go the same route as Redrum...
1- 4800 lion of the Rx
1- 2400 lion for the ignition
2 regulated reliaswitches
ORIGINAL: Redrum
Hey Blue..
I just got a setup from Fromeco..I wanted to go with 3 2400 packs but Kurt actually talked me out of it..even though I would be spending LESS money! Instead I got a 4800 which are just 2 2400's wired together..a 2400 with 2 super regulated reliaswitchs..They come with a charging lead that you can either keep inside the fuse or you can use those charge jacks that mount to the side of the fuse..
