RE: new Arf Boomerang 14lb thrust
Guys
Some more pics of the L/G install. In pic 1 I have epoxied a U shaped 6mm ply plate on top of the hardwood mounting rails to strengthen this area. The gear mounting screws will be 1" long.If you are planning to use retracts the supplied wheels will not fit the wheel wells I am using 66mm Intairco wheels.
Pic 2 is the nosewheel cut out with the gear in position on the new 6mm ply mount. Pic 3 gear mount from inside ready to be Aeropoxied in place.
Going to St Andrews to play golf at the weekend catch up Sunday night.
John
