RCU Forums - View Single Post - Get the Reflex and AFP conversion tool for AFPD here
Old 03-04-2005 | 11:35 AM
  #44
codepunk
Default RE: Get the Reflex and AFP conversion tool for AFPD here
Can't tell if you're being sarcastic or not. The screenshot should be pretty self explanatory.
In a nutshell, it will
1. Perform the scenery conversion like the original converter (most of the same code will be used)
2. Take any panoramic image and create a scenery for it
3. Install an AFP or AFPD aircraft that you downloaded
4. Create a new aircraft based on configuration. This one needs a little research, but I got the idea from the Martin post in the Ikarus forum. Everyone wants to know "what's your setup for such and such aircraft" to which a reply is sent with a bunch of parameters like "set prop pitch to x.xx". Well, it would be nice to have a way to just email someone a file (or upload somewhere for download) and they can just import those settings without having to manually set them all. So, I hope it works. We'll have to wait and see.
