RCU Forums - View Single Post - My coming setup
Old 03-04-2005 | 11:57 PM
piper_chuck's Avatar
piper_chuck
My Feedback: (12)
Default RE: My coming setup
ORIGINAL: wildwobby
how is it?
Avistar 40 II MonoKote ARF $99.99
O.S. .46 AX ABL w/Muffler $114.99
7CAF FM R127DF 4 S3151 38 $264.99
You could save $100 by buying a less expensive engine, radio, and servos. The S3151s are overkill for a trainer, but as part of the set, they're not much more, so go for it. You have not chosen bad stuff, just spending more than necessary.
Associated Factory Team Glow Starter Blue $19.99
Hobbico Accu-Glo II Power Panel $29.99
Hobbico TorqMaster LC 12V 7Amp Battery $17.99
Hobbico 12 Volt Charger U/L Listed $10.99
There's a mismatch with the above 4 items. You've chosen a power panel, 12v battery, and charger, but you are getting nothing to plug into it. You could ditch the glow starter and get a glow lead that plugs into the panel. Here's a tip, being able to adjust the power to the glow plug (using the knob on the power panel) makes hand starting much easier than with a glow starter. And, as has already been mentioned, exactly where are you going to put the panel.
2 Master Airscrew 10x6 G/F Nylon Propeller $2.29
Check the manual for your engine. The minimum recommended prop is 10.5x6. Go with one in the recommended range, with a larger diameter and smaller pitch. This is like being in a low gear in the car, plenty of pull, but not such high top end speed. It will make takeoffs easier, and help slow the plane down for landing.
Tower Hobbies #64 Rubber Bands 1/4lb $1.59
Great Planes Silicone Fuel Tubing Standard 3' $2.19
Tower Hobbies 6-Minute Epoxy 4 oz. $4.99
Do yourself a favor, buy 30 minute epoxy instead of 6 minute. You need the extra time to get the glue spread around and align the parts. Plus you'll get a better bond. I don't even bother keeping 5 minute epoxy in my shop anymore, it's such a firedrill to mix it, spread it around and align things before it starts to gel.
Hobbico Steel T-Pins 1" (100) $2.09
Hobbico Latex Foam Rubber 1/4" $2.49
Great Planes Epoxy Mixing Sticks (50) $2.49
Great Planes Epoxy Mixing Cups (50) $2.99
Great Planes Epoxy Brushes (6) $1.29
chicken stick $3.49
TOTAL-------------------------------------------------$590.11
So? is this a good set up? tell me what you think! Thanks!
Missing essential (IMO) items:
Spare glow plugs OS #8
Glow plug wrench
Fuel pump (manual works fine)
Battery tester (to monitor the condition of the receiver battery)
Receiver switch and charge jack holder (better than mounting the switch on the outside of the plane, and the jack holder allows easy access for testing the battery condition.
Fuel can hardware (so you can connect the fuel pump lines without opening the fuel can all the time. Sometimes these come with the fuel pump.
Do you have a square for checking the alignment of the tail surfaces?
Prop reamer (often the hole in the prop is smaller than the engine shaft)
Prop balancer (many don't bother balancing props, but everyone should)
it comes with 2 receivers a hi and a lo, what is the difference?
It will come with EITHER a high or low band receiver, based on the frequency you pick. There is no difference between the two, Futaba just tunes some of their receivers to work best in the higher frequency numbers, and others in the lower frequency numbers. Your set will get the appropriate receiver for the channel you chose, 38.
