RCU Forums - View Single Post - OFFICAL TIPS AND TRICKS THREAD
Old 03-05-2005 | 11:07 PM
speedy1379
Default RE: OFFICAL TIPS AND TRICKS THREAD
[If you have dogbones and get sick of them throwing out those crappy little red o-rings, get pvc washers like are used in water hoses. Use a hobby knife to cut off a small piece of the tree that the washers come on and use it in place of the o-ring. Just trim it so that your dogbones have the right spacing. It's large enough that it can't be thrown out of the outdrive/axle, so problem solved.]
Or you could just cut a piece of fuel line and slip it in the drive cups...mine was in there for 2 years till the cups wore out...then I went to the CVD's.
