ORIGINAL: newbtoRC
bubba i lied i am going to ask a few more questions be fore i sleep.
I asked this in another thread, but does blowdrying the covering get wrinkles out?
also,
I guess we will check the plane tommrow so i won't ask more. Oh, I got one
Why do you use #64 rubberbands?
Oh and we are going to the same spot, but luckily we are going early sunday morning when there should be no cars for about 2 hours atleast. Probably longer. Its gonna be a blazing 65 degrees. I am ready though. One last check of the wind and i will be ready to go
anyways...
Yep, you lied
I'm tellin your mommy
J/K !!!
If you use the normal hair dryer then it will take forever as it really does not get hot enough to act quickly although it can be done. Most hobby shops have heat guns for around 20 bucks
As far as #64 rubber bands and I am guessing here is because they are wider and stronger than the normal everyday rubberbands but as I said I am sure sure of the actual reasoning, just a guess.
I would love to see 60+ degrees. The warmest it's been here is 50 degrees and that was a month ago for one or two days.
It's been anywhere from 5 above to 40 above here with a high tomorrow of 45 but 30mph winds...Oh well
