RCU Forums - View Single Post - Get the Reflex and AFP conversion tool for AFPD here
Old 03-06-2005 | 08:33 AM
  #46
dafid's Avatar
dafid
Default RE: Get the Reflex and AFP conversion tool for AFPD here
Hi GUYS
You can also transfer scenerys from the reflex sim to AFPD sim useing the conversion tool
all you need to do is go into REFLEX sims scenery directory wich is called Umwelt click on it then Wlp click on it then pick a scenery folder open it and copy all the files in that folder go back to your desk top make new folder paste copied files into new folder rename it as exactly the scenery name but befor you convert you must add to this folder a geo file i used an old one i copied an pasted in the folder once this is done use the coversion tool see screen shots.
ID:	238757   Click image for larger version
ID:	238758   Click image for larger version
