RCU Forums - View Single Post - usefull tips
Thread: usefull tips
Old 03-06-2005 | 10:52 PM
timmytimmy14
Default RE: usefull tips
use the 20% byrons fuel. some hyper 7 PBS's have a pull start and a black headed 8 port, and some have no pull start with a purple headed 8 port. prey that you get the pull start and black head. the black head cools better and makes tuning easier. either way it comes with a starter box and you should definatley use it. if it comes with the pull starter use that to break in the motor. if you use the starter box then the rubber wheel on the starter box will not survive, you will destroy it if you use the starter box during break in. if it doesn't come with the pull start then here is the link...
http://www.horizonhobby.com/Shop/ByC...rodID=OFN53025
good luck with your new hyper and once again, if you have any questions then PM me.
