RCU Forums - View Single Post - HELP Replacing BVM tires
Old 09-17-2002 | 09:23 PM
SUMMIT120
Default replacing BVM tires
If you can's stomp hard enough you can place the tire and wheel between two pieces of wood and use C-clamps or a vice to apply pressure to the whole assembly. The tire will usually slip over the rim without any trouble. A soapy solution for lubrication seems to help as well.
Mike Danchak
