RCU Forums - View Single Post - Receiver Battery need foam?
Old 03-07-2005 | 11:26 AM
Geistware
My Feedback: (16)
Default RE: Receiver Battery need foam?
I have seen a couple of velcro types. If you use the stuff that is like wool on one side, then it should be OK. It will allow high frequencies to be absorbed but low frequencies will pass (but no harm should be done) the other velcro makes a tight bond to the surface. It uses little splines that interconnect to hold the two halves together. I would not use this type.
