RE: Debonair Engine
BryanH:
Since I'm in the process of building my 2nd Deb fuselage (because of the dang 0S .40 LA!), I can help you avoid the 'turd'. I also have the brown pvc pipe, but I painted it with several coats of white then seveal coats of yellow. It came out great! I'm using a spray paint called 'Fusion' which I believe is made by Krylon. I'm told it's also fuel proof...we'll see.
I cut out all the holes, etc, before painting. I'll send a finished pic if the thing turns out decent.
Regards,
SS
