RCU Forums - View Single Post - U-Can-Do-3D Video
Old 09-18-2002 | 12:39 PM
f2racer
Default U-Can-Do-3D Video
Awesome video. Hopefully mine will fly 1/2 as nice. I'm going with a TT F-91S to start out with, if that's not enough, I'll stick my YS up front. I'm only 3 tanks into break in on the TT and it's already turning 9000 rpm with an APC 15x6 prop on 15% nitro running pretty rich (ain't idling worth sh*t yet though, maybe another 2 tanks and I'll try to take it up). I hoping to get mid to high 9ks once it's completely broken in. Hopefully this will offset the extra 5oz of weight compared to the Saito. I'm also planning on using HS-77s (weighs about .3oz lighter than standard servos each, 65oz-in on 4.8v and, .18 sec for 60 degrees travel; I've had good luck substituting this servo on the rudder of my 40 sized pattern plane) on the ailerons and elevators, a HS-605 on the rudder, and a micro/mini on the throttle, an FMA micro RX, and a 4 cell 1650mAh NiMH pack. I'm hopeful that the plane turns out just a hair above 7lbs...
What do you guys think?
