RE: stall warning device?
II have had similar thoughts. I was thinking of measuring pressure at the top and bottom of the wing close to the leading edge.
If a slight negative pressure exists at the top we have lift. If the pressure differential falls then it would activate the stall device. This could be horn, or switch . for high lift device etc. Is this feasible?
