RCU Forums - View Single Post - Magic - pull - pull is very stiff - help
Old 09-19-2002 | 02:56 PM
George E.'s Avatar
George E.
My Feedback: (16)
Default Magic - pull - pull is very stiff - help
Rainer
I should have mentioned that the Magic is a not a pull/pull in the usual sense since it uses rods and not wires. On a pull/pull you should have the holes in the control horns SLIGHTLY aft of the hinge line. On the Magic the wires are stiff and won't go slack so make sure the holes in the control horns are EXACTLY on the hinge line.
The Ackerman problem is most noticable on large throws.
