RE: Let the building begin.... (4*60)
Also, instead of using a Y cable to connect the ailerons, if you have a computer radio you can use lile channel 2 and 5 to connect the ailerons and then you can program them to function as flaperons. Although, if you built the wing at the standard width, you definately wouldn't need flaps.
