RCU Forums - View Single Post - OS AX Engines
Old 03-08-2005 | 03:58 PM
bruce88123
Default RE: OS AX Engines
Best I could find was complete valve assy. os does not list just the needle.
In fact the Tower pg below states the needle is not available as a separate item. If you use different needle, you will probably compromise tuning, your choice.
http://www2.towerhobbies.com/cgi-bin...00&FVPROFIL=++
$18
if you need bracket, here it is:
http://www2.towerhobbies.com/cgi-bin...?&I=LXGCV2&P=V
Good luck.
