RE: OFFICAL TIPS AND TRICKS THREAD
to keep your body from smacking doun on the mounts when you land off a jump put little pices of fule line between the mount and the body.
If you find yourself always running out of the plastic shock spacers use Zip Ties in place of the spacer.
When watterprofing servos with a baloon, the hole you put in it for the servo horn to attach, put a little dob of greese on there to keep watter form entering. And some greese where the wires come out too is nice.
If you keep breaking a particuliar part on your vechile ex: a spindle, take one off a similar car but diffrent make and costomize it to work. Hey I got xxx-nt hub carriers and hubs/spindles on my traxxas rustler.
When a part breaks out in the field it can usually be fixed with CA, mechanics wire/paper clips, or rubber bands. I mean I broke the top part of a shock cap and held it back on with rubber bands and it worked mint.
