RCU Forums - View Single Post - 4 Stroke high speed needle setting.
Old 03-09-2005 | 03:34 PM
LarryQ
Default 4 Stroke high speed needle setting.
Forgive me..but I need to confirm something.
With a 2stroke, I have no problem setting the high speed needle.
But this same procedure could cause problems on a 4-stroke.
If I lean to max RPM then back off to slightly rich, I stand the risk of detonation BIG TIME.
And if I use RPM, I can richen it up to whatever I want (if the prop isn't loading the engine enough).
Right now, I'm not sure if my YS 110 is going to be happy with a Master Airscrew 3-blade 14x7 prop.
I can richen it to @9300-9500...but she is really rich.(Tons of smoke and a gurggle break at high rpm)
good for break in...but I don't think she is going to be very happy.
otherwise It seems to overspin that prop to 10,500.
I risk floating a valve at that RPM.
Is it too lean?...well that's my problem..I just can't tell straight away.
What should I look for to make sure she is happy, and not leaned too far?
This is my first 4-stroke..but I'm a fast learner.
What I've read says to richen it to @ 500 rpm off peak RPM.
