4 Stroke high speed needle setting.
OK
Forgive me..but I need to confirm something.
With a 2stroke, I have no problem setting the high speed needle.
But this same procedure could cause problems on a 4-stroke.
If I lean to max RPM then back off to slightly rich, I stand the risk of detonation BIG TIME.
And if I use RPM, I can richen it up to whatever I want (if the prop isn't loading the engine enough).
Right now, I'm not sure if my YS 110 is going to be happy with a Master Airscrew 3-blade 14x7 prop.
I can richen it to @9300-9500...but she is really rich.(Tons of smoke and a gurggle break at high rpm)
good for break in...but I don't think she is going to be very happy.
otherwise It seems to overspin that prop to 10,500.
I risk floating a valve at that RPM.
Is it too lean?...well that's my problem..I just can't tell straight away.
What should I look for to make sure she is happy, and not leaned too far?
This is my first 4-stroke..but I'm a fast learner.
What I've read says to richen it to @ 500 rpm off peak RPM.
ND
you shouldn't be using the mixture control to adjust max rpm. instead, get the correct prop that allows it to run at the optimum rpm, and back off from there. 10.5k does seem high for that size engine, although that is just a guess...
My Feedback: (24)
ORIGINAL: LarryQ
The YS 110 is happiest between 9300 and 9500 rpm. This is where the engine develops the most power. I usually richen mine 300-400 rpm off peak.
choose a larger prop. One that will stay below 10000 rpm when leaned out. Then adjust mixture to the rich side of max rpm, and you will be OK.
You have to stay clear of valve float rpm when in flight, and it has to be done with the prop load, not with overly rich mixtures.
OK
I just ordered a couple 14X9 3-blade props.
I will have to check out the graupners...
What have you gotten with the 14x9's??
Larry
Larry
OK
As I am performing the RPM check on the ground....I would think a reading of @9000 on the ground with a 14X9 would be about right when it unloads in the air.
Before I order a couple Graupner 14X7's do you have a tach reading?
I really don't need more 14X7's if they won't load up my 110 properly.
I am running an OS "F" plug and fuel is Powermaster YS 20/20
If the 14X9 loads too much I could always go to 30% Heli fuel as long as it has 20% oil content.
MI
The problem may be with the MAS props. One of the engine columnists opined recently that on a pitch gauge MAS props all checked one inch flatter in pitch than they were marked; a 14x7 was actually a 14x6. This accounted for his slightly higher RPM with the MAS, NOT superior design or materials. Jim
My Feedback: (24)
9K rpm was peak rpm on the ground, so that would be roughly 8600 rpm richened down. To me, 8600 rpm means too much load on the engine.
Sorry, I don't have a tach reading for the Graupner 14x7 3-blade. Based on experience with Graupner 2-blade props, I am 99% certain that the Graupner 14x7 3-blade would load the engine more than the MA 14x7 3-blade. You might want to order just one to test it out.
OK
Ahhh..after richening it was 8600....
What about 30% Heli fuel..that should help some?
I ordered 3 Graupners 14X7...Hell Shipping as as much as the props.....I REALLY WANT TO MAIDEN my Miss America Saturday!
