RCU Forums - View Single Post - 4 Stroke high speed needle setting.
Old 03-09-2005 | 03:52 PM
smokingcrater
Default RE: 4 Stroke high speed needle setting.
you shouldn't be using the mixture control to adjust max rpm. instead, get the correct prop that allows it to run at the optimum rpm, and back off from there. 10.5k does seem high for that size engine, although that is just a guess...
