RE: 4 Stroke high speed needle setting.
choose a larger prop. One that will stay below 10000 rpm when leaned out. Then adjust mixture to the rich side of max rpm, and you will be OK.
You have to stay clear of valve float rpm when in flight, and it has to be done with the prop load, not with overly rich mixtures.
