RCU Forums - View Single Post - What engine makes the lightest conversion?
Old 03-09-2005 | 08:57 PM
ZAGNUT's Avatar
ZAGNUT
Default RE: What engine makes the lightest conversion?
the little kawasaki 20+cc engines will come out far lighter than the echo 21.2. these are normally found on hedge trimmers and because the blades usually break from abuse the power heads can be found in shops for cheap.
i also suspect that these will make quite a bit more power than the little echo but have yet to run the couple that i have.
dave
