RE: Genesis weird problem
I only had those set screws in my third gear drum. Be carefull with those, I had to do the same thing you did and when I ran the truck again the set screws worked themselves loose. One actually came out and lodged itself between the drum and shoe. i then took it apart again and used JB weld on the threads to lock them into place. So far i haven't had any probs.
