RCU Forums - View Single Post - Biplanes for 3d any good?
Old 03-11-2005 | 12:24 AM
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: Biplanes for 3d any good?
ORIGINAL: seanychen
I have a YS 140 DZ on my DPM Ultimate 120. Here's a video of it:
http://www.pedrofrigola.com/Ultimate%20Show.wmv
My DZ swings Pro Zinger 18x8 @ 8500 rpm, which is a little stronger than Saito 180, I think. But I am sure Saito 180 swing a Menz 18x6 will haul it around just as good.
By the way, my 2-lb engine makes the DPM Ultimate nose heavy. When I have cowl on, I have the battery pack at the tail to balance it at the middle of the CG range. Saito 180 will be perfect, as it is a little lighter than my 140 DZ.
Joe,
With a Moki 2.1, I don't know how you would balance the plane. It's not like most other 1/4 scale aerobats with 3 servos mounted at the tail. There is no servo mounted at the tail. This plane also has a short landing gear, so 20" prop wouldn't fare so well.
Sean, I didn't know that you couldn't mount the servos in the tail. That's pretty weird. I saw Dave Patrick's booth at an RC show in Chicago and he had a Moki mounted inside the Ultimate 120. My Edge 540T 26% came with the option of putting the elevator servos in the tail so I assumed all his planes were that way. He loves to make all his planes pull pull, too many cables for me. My Edge is still a little nose heavy with the 5945's in the tail. The battery pushed a little aft will resolve that.
