RCU Forums - View Single Post - OFFICAL TIPS AND TRICKS THREAD
Old 03-12-2005 | 12:31 AM
  #39
brownstone101's Avatar
brownstone101
Default RE: OFFICAL TIPS AND TRICKS THREAD
ok this is a good one shock boots take a water balloon cut a small hole on the bottom and cut the top rim off then take spring off slip it over the shock body and bottom part the cut a small needle size hole on side so air can move put back together and you have a good shock boot i will get pic
ID:	242474   Click image for larger version
ID:	242475   Click image for larger version
ID:	242476   Click image for larger version
