RE: Does it go this way or this way...DOHH!!
Turbo B Good update. Hey...it says USA on the lower rod bearing on my Homlite engine!!! Good to see that USA on anything. If you did not seperate rod from piston...you can sometimes tell the correct way. The piston is often a little more varnished by the exhaust port. So if when you slip piston back in cyl with the varnished face lined up with exhaust port...you most likely got it back right. Smooth Landings Capt,n
