RE: Ailerons on a Kadet Senior?
I put a one inch block under each wing tip at the last rib ,worked well. I used full ailerons on the wing. They were about two inches as I remember, worked well with in the wing servos. See if you can find a Sr. ARF around and compare if you feel the need, but my method worked well for me.
This is areally great plane and you should have a lot of fun and learn a lot.
