RCU Forums - View Single Post - Get the Reflex and AFP conversion tool for AFPD here
Old 03-13-2005 | 12:17 AM
  #54
GCL
Default RE: Get the Reflex and AFP conversion tool for AFPD here
ORIGINAL: codepunk
The tool doesn't overwrite any AFPD files so I'm not sure why it's crashing. Here are some questions for you.
1. Does it crash if you're flying in a regular AFPD scene and then try to switch to another one?
Ok, I converted Reflex files(s). Elmshorner, FTG Borstel, MFG Heist, Modellflugverien, Sporthalle, etc.
I proceeded to convert with program (Converter program) and no problems on creating files and go fly.
I went to AFPD and selected a scene. I quit flying the scene. Went to main screen to select Scenery and AFPD crashes. HOWEVER, it appears that it may be random or a specific scene (not sure,YET). A dialog box appears and I click on cancel and that's it. I am in the process of adding one Reflex scene at a time and see if it crashes. I then take it out if it appears to do so. By the way, I did re-install AFPD just to be sure.
Maybe, it appears that if I "fly" a reflex converted scene and select a AFPD scene, AFPD crashes. I will check on a common factor.
2. Which Reflex scenes exactly are you using? If you can provide a link, please do.
See above names.
3. What does the crash do? System lockup? Illegal instruction dialog? App hang only?
AFPD has generated errors and will close down. I click on cancel to close box.
4. Did you apply the latest AFPD patch?
YES ! Latest patch installed
5. Do you have the music feature enabled?
Music is DISABLED
6. Are you now, or have you ever been, a member of the Communist party?
Nein !
-Mark
