RCU Forums - View Single Post - i need help genesis
Old 03-13-2005 | 04:41 AM
jadda
Default RE: i need help genesis
Hi crazyorhigh
Have you checked the temp on the engine I would also check the settings on the carb, when you are at break in the needle setting should be 4 -4 1/2 turns out on the main needle, 1/2 -0 turns in from flush on the low needle and idle you as low as you can but not to low the truck shouldn't move when it idles.
