i need help genesis
VA
i'm having trouble keeping the truck running during break in.runs for about a minute then cuts off.i've tried the idle screw.it happens when the idle is where i think it should be.i'm open for suggestions.nice truck but if i can't break it in, it will become 4 sale quick.i,m ready to play this maybe my first nitro powered r/c but i've had an rc10,jrx2,jrxt,still have 12L,10Lspeedway.it'a been awile.
Hi crazyorhigh
Have you checked the temp on the engine I would also check the settings on the carb, when you are at break in the needle setting should be 4 -4 1/2 turns out on the main needle, 1/2 -0 turns in from flush on the low needle and idle you as low as you can but not to low the truck shouldn't move when it idles.
