RCU Forums - View Single Post - 4*60 Right thrust.....have you?
Old 03-13-2005 | 05:09 PM
exeter_acres's Avatar
exeter_acres
Default 4*60 Right thrust.....have you?
I searched, but 4*60 is tough to search for here
Flying my 4*60 ARF with a Magnum .91...
I've increased the rudder size and am in the process of building larger elevators...
This plane is a hoot...
Knife edges pretty well with the larger rudder....
even had it hovering a bit today....but it was a bit windy!!
But... noticed that I had to use quite a bit of right rudder on the uplines and it would almost alway fall off to the left
Has anyone added right thrust to their 4*60....
It shouldn't be too dificult to add a washer or two under the mount...
But just curious if any has done this with their 4*60?
Thanks for the opinions....
