 4*60 Right thrust.....have you? >
Old 03-13-2005 | 05:09 PM
exeter_acres's Avatar
Default 4*60 Right thrust.....have you?
I searched, but 4*60 is tough to search for here
Flying my 4*60 ARF with a Magnum .91...
I've increased the rudder size and am in the process of building larger elevators...
This plane is a hoot...
Knife edges pretty well with the larger rudder....
even had it hovering a bit today....but it was a bit windy!!
But... noticed that I had to use quite a bit of right rudder on the uplines and it would almost alway fall off to the left
Has anyone added right thrust to their 4*60....
It shouldn't be too dificult to add a washer or two under the mount...
But just curious if any has done this with their 4*60?
Thanks for the opinions....
Old 03-13-2005 | 05:24 PM
bubbagates's Avatar
My Feedback: (32)
Default RE: 4*60 Right thrust.....have you?
Exeter,
I added 1 degree right thrust and now the uplines are straight. I am flying the OS91 Surpass turning a 15X6 prop
Just add one washer to each of the left mounting bolts between the firewall and the mount. I used rubber washers 1/16 inch thick so that they would not dig into the firewall
Old 03-13-2005 | 05:33 PM
Great....we are using similar engines. and I have been using a 15 x 6....just switched to a 15 x 4W to play with a bit and it is fun....
I'll add a couple washers and see!
Thanks for the input
Old 03-14-2005 | 12:01 PM
We now have some off-set wedges made of glass-filled nylon. These can be used on firewall or rail mounts and come in 1 degree and 2 1/2 degree tapers.
FYI.
E-mail for details.
Ray
Old 03-14-2005 | 02:52 PM
Salty25's Avatar
My Feedback: (9)
Exeter,
I HAD a 4*60 that I flew with a Magnum .75 for a few years. I was able to get that plane to hover and my uplines were pretty straight. I didn't have any right thrust in the plane, mounted the engine straight. I flew it with a 12X6 and a 13X6, depending on how I wanted to fly that day.
I lost it when the wing folded on me during a loop. I didn't think I was that fast but guess it was time.
The rudder on mine was larger also, but I think the elevators were stock. I put a pull-pull setup on the rudder.
Hope you enjoy yours.
Old 03-14-2005 | 04:33 PM
Well...I added one washer on the left side.....
Will see next weekend... Boy, one washer sure doesn't seem like much!
But I will test it out and see.....
I'm also going to play with moving my CG back just a bit......
I moved my battery and Rx from the space in front of the servos to the area behind the servos... will test it out
